Tom's Hardware > Forum > Audio > Audio Technology > Cap I.D Question (Help)
Forum Audio : Audio Technology - Cap I.D Question (Help)
Archived from groups: alt.guitar.amps,rec.antiques.radio+phono,rec.audio.tech,rec.audio.tubes (More info?)
Hello,
I have a stock of Soshin 2J224K caps. They were in a bin marked 600 volt,
but I have no way to confirm. I also have no idea what value these are
(.22, .47uf)? Please post back if you can clue me into what value these are?
Thanks,
Kelly
Sponsored Links
KSM wrote:
> Hello,
Hook 'em up to 600V. If they don't smoke, they're OK. ;-)
.22uF. "224" is capacitor-speak; it works like this:
The first two digits are the value, and the last digit is
the multiplier. (22 followed by four zeros, in this case.)
The result is in pF. Move the decimal point six places
to the left to get uF.
Lord Valve
Tone Chaperone
VISIT MY WEBSITE: http://www.nebsnow.com/LordValve
I specialize in top quality HAND SELECTED NOS and
current-production vacuum tubes for guitar and
bass amps. Good prices, fast service.
QSC amps, RNC compressors, lots of other good stuff!
Partial Client List: * Derek Trucks/Allman Brothers Band *
* Meatloaf * Catherine Wheel * Yo La Tengo * Let's Go Bowling *
* John Hall * Tyrin Benoit * Eugene Fodor * Dale Bruning *
* Komet Amplification * Dr. Z * Maven Peal * Blockhead Amps *
* Jim Kelley * Balls Amplification * Roccaforte Amplifiers *
* Gerhart Amplification * The Right Half of AGA * Lots More *
NBS Electronics, 230 South Broadway, Denver, CO 80209-1510
Phone orders/tech support after 1:30 PM Denver time at 303-778-1156
- Our 23rd Year -
VISA - MASTERCARD - PAYPAL
"The only trouble with being blind is...you can't see a goddamn thing!"
-Ray Charles-
Reply to Anonymous
"KSM" <nospam@nospam.net> said:
>Hello,
>Thanks,
>Kelly
The 224 indicates 22 with 4 zeroes in pF, so 220 nF or .22 uF.
Voltage can be determined by size, with caution.
A cap of 220 nF 600 V would be about 6 x 3 cm.
Sometimes it helps to compare size with caps of known value and
voltage and the same dielectric.
Sander deWaal
Vacuum Audio Consultancy
Reply to Anonymous
Scott, re your capacitors.. they should be .22uf.
The formalism with the part # is as follows:
221K = 220uf
222K = 22uf
223K = 2.2uf
224K = .22uf
225K = .022uf
226K = .0022uf and on
also the other question re caps in parallel. the voltage rating of
the caps stays the same when in parallel and doubles when in
series. three in series triples and so on. warning though, with
series caps, leakage in one or more of the caps will skew the
overall voltage rating downward. and kaboom.
morris.
"KSM" <nospam@nospam.net> wrote in message
news:u%7oc.16305$V97.3858@newsread1.news.pas.earthlink.net...
> Hello,
are?
> Thanks,
> Kelly
Reply to Anonymous
> 221K = 220uf
> 222K = 22uf
> 223K = 2.2uf
> 224K = .22uf <-- This one is right.
> 225K = .022uf
Gaaack, you went the wrong way.
221K = 220 pF (pico)
222K = 2200 pF or 0.0022 uF
223K = 22000 pF or 0.022 uF
224K = 220000 pF or 0.22 uF
225K = 2200000 pF or 2.2 uF
226K = 22000000 pF or 22 uF
Jeff
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." Benjamin Franklin
"A life lived in fear is a life half lived."
Tara Morice as Fran, from the movie "Strictly Ballroom"
Reply to Anonymous
Kelly:
You have been correctly shown that the 224 part of the nomenclature is 0.22
µf (22 followed by 4 zeros - pf.). The leading 2J and the K suffix indicate
the voltage and tolerance/stability. But, I can no longer find my magic
decoder ring, and I would be very suspicious of the voltage rating, as Japan
manufactured very few "high voltage" capacitors over 200V. 50V, 100V,and
200V are plentiful; 400V are rare and 600V difficult to find. As a guess, I
would suspect those are 200 volt jobs.
Crazy George
Remove N O and S P A M imbedded in return address
Reply to Anonymous
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
