Archived from groups: microsoft.public.windowsxp.games (More info?)
Help needed!
I running XP and when I plug in my stick through the usb connection and
enter sidewinder auto detect in th game controller panel nothing happens. I
continue to get "Undetected" in the panel and the sticks doesn't work in the
game. Strange thing is I have had it working previously and played flight
sims. Previously the computer detected the stick and I was able to use it.
For some reason now it wont detect. Can ayone help
Thanks
Persistent Pete
Is the USB port known to be working correctly with other USB devices?
Cari (MS-MVP)
Printing & Imaging
"pete" <pete@discussions.microsoft.com> wrote in message
news:719CA86F-FB90-4037-9029-D0ACBD0CEB9D@microsoft.com...
> Help needed!
> I
> the
> it.
> Thanks
> Persistent Pete
Thanks for the quick response Cari. Yes in answer to your question, tried
downloading some photos tonight via USB and it worked. Checked in device
manager and all USB are functioning properly. Am stumped!
Persistent Pete
> Cari (MS-MVP)
> Printing & Imaging
> > Help needed!
> > I
> > the
> > it.
> > Thanks
> > Persistent Pete
Try the joystick in a friend's PC... it might have gone to joystick heaven
At least it might narrow down the problem a bit.
Cari (MS-MVP)
Printing & Imaging
news:9555354F-C23D-4396-A94A-BECB826FB85A@microsoft.com...
> Persistent Pete
>> Cari (MS-MVP)
>> Printing & Imaging
>> > Help needed!
>> > happens.
>> > I
>> > in
>> > the
>> > flight
>> > it.
>> > Thanks
>> > Persistent Pete
hey thanks Cari for your help. The stick has now decided it will work and
the computer is recognizing it. Can't work that one out, but maybe greater
forces are at work!! Thanks again
Persistent Pete
> Cari (MS-MVP)
> Printing & Imaging
> > Persistent Pete
> >> Cari (MS-MVP)
> >> Printing & Imaging
> >> > Help needed!
> >> > happens.
> >> > I
> >> > in
> >> > the
> >> > flight
> >> > it.
> >> > Thanks
> >> > Persistent Pete
There are some capacitors in some of the USB joysticks that get completely
charged and then the system will fail to see this device if left plugged in
all the time. If you are careful you can unplug the device and short the 4
USB pins in the device temporarily, remove the shorting device and then plug
it back in the system and it should work fine.
This posting is provided "AS IS" with no warranties, and confers no rights
news:C24E158F-5B95-4A9F-B124-DD3702945242@microsoft.com...
> greater
> Persistent Pete
>> heaven
>> Cari (MS-MVP)
>> Printing & Imaging
>> > tried
>> > device
>> > Persistent Pete
>> >> Cari (MS-MVP)
>> >> Printing & Imaging
>> >> > Help needed!
>> >> > and
>> >> > happens.
>> >> > I
>> >> > work
>> >> > in
>> >> > the
>> >> > flight
>> >> > use
>> >> > it.
>> >> > Thanks
>> >> > Persistent Pete
