Hello everybody I would like some assistance on this new build that I am creating. I'm trying to keep it in the 700$ range so it would be helpful if any of you have advice on where I could buy something cheaper that would have the same effect. I've never been able to play games on max so I hope that this build will be able to play most games I play on max. So far I have:
Gigabyte AMD Radeon HD 7950 3GB GDDR5 $299.99 -
http://www.amazon.com/Gigabyte-Mini-Displayport-PCI-Express-Graphic-GV-R795WF3-3GD/dp/B007581QHG/ref=sr_1_3?m=ATVPDKIKX0DER&s=electronics&ie=UTF8&qid=1353547378&sr=1-3
i5 3570K 3.4GHz LGA 1155 Processor $189.99 - http://microcenter.com/product/388577/Core_i5_3570K_34GHz_LGA_1155_Processor
ASRock Z77 Extreme4 LGA 1155 Z77 ATX Intel Motherboard $129.99 - http://www.microcenter.com/product/387554/Z77_Extreme4_LGA_1155_Z77_ATX_Intel_Motherboard
Ballistix Sport 8GB DDR3-1600 $44.99 - http://microcenter.com/product/382101/Ballistix_Sport_8GB_DDR3-1600_(PC3-12800)_CL9_Dual_Channel_Desktop_Memory_Kit_(Two_4GB_Memory_Modules)
SeaSonic M12II 620 Bronze 620W ATX12V $89.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
CM Storm Scout - Gaming Mid Tower Computer Case $67.52 -
http://www.amazon.com/CM-Storm-Scout-Computer-SGC-2000-KKN1-GP/dp/B00243HHNY
Total of this list = $822.47
It would be really helpful if you point out anything wrong with the build ie anythings that are not compatible or anything like that. Keep in mind that this is my first time getting all my own parts from scratch. Thank you for your help.
EDIT: Any parts that are not mentioned such as HDD, CD-ROM, and OS are already covered.
