Hi,
I have an underground cable connecting a classroom to the main server.
If I plug any computer directly into the underground cable it connects to the server fine.
If I plug a switch into the cable, none of the computers connected to the switch gets an IP address from the server. When I try to assign manual IP addresses I also can't connect.
But when I use the same switch and plug it into the server using a shorter cable everything works.
What could be the problem? Could it be a cross over vs straight through wiring problem? Any other suggestions?
