will the following 700 watt 88% effiecent powersupply be able to power my asus sabertooth z77 with I7 3770k, crosair h100, 1 120mm fan (standard led fan CM690ii) and 2 gtx 680's in SLI (currently running 1 680 no problem at al)
Model
RS-700-ASAB
Type
ATX 12V V2.3
Input Voltage
180-264V (Auto Range)
Input Current
6A
Input Frequency Range
47Hz-53Hz
PFC Active
PFC (>0.9)
Power Good Signal
100-500ms
Hold Up Time
17ms
Efficiency
88% Typically
MTBF
100,000 Hours
Protection
OVP / OPP / SCP
Output Capacity
700W
Operation Temperature
0~40°C (Nominal Input Voltage)
Regulatory
TUV / GOST / CE / C-Tick / CCC / KC
Fan
120mm
Connector
M / B 24 pins x 1
CPU 4 + 4 pins x 2
PCI-e 6+2 pins x 4
SATA x 6
Peripheral 4 pins x 3
Floppy 4 pins x 1
Model
RS-700-ASAB
Type
ATX 12V V2.3
Input Voltage
Input Current
6A
47Hz-53Hz
PFC Active
PFC (>0.9)
Power Good Signal
100-500ms
Hold Up Time
17ms
Efficiency
88% Typically
MTBF
100,000 Hours
Protection
OVP / OPP / SCP
Output Capacity
700W
Regulatory
Fan
120mm
Connector
M / B 24 pins x 1
CPU 4 + 4 pins x 2
PCI-e 6+2 pins x 4
SATA x 6
Floppy 4 pins x 1
