What parts should I buy to upgrade my current computer?
My current computer has:
CPU: AMD Athlon 64 X2 Dual-Core 6000+ 3.0 GHz Processor
Motherboard: ASUS M2N-E Motherboard
Memory: 2G RAM
Storage: 500G (not sure what brand but I bought this in 2006)
Video Card: Radeon 5770 HD
Case: Thermaltake Armor Jr. Mid Tower Case
Power Supply: Corsair TX650W 650W ATX 12V 52A 24PIN ATX Power Supply Active PFC 120MM Fan
Optical Drive: I have one but it was bought in 2006, will it still be compatible with an upgrade?
Monitor: Samsung SyncMaster 1680 x 1050
My budget is $500 and I am planning to just upgrade my CPU, motherboard, memory and storage. With my 5770, I seem to be able to run borderlands 2 (can sometimes get 40 fps) and some other games... HOWEVER there is a lot of stuttering with newer games. I am pretty sure my system is bottle necking my GPU, am I right? If I upgrade can I expect a significant increase in fps?
What do you guys think of crossfiring 5770s, would that be a good option if I wanted a cheap graphics performance upgrade. It would be great if I could run Far Cry 3 at 1680 x 1050 resolution. Or should I just go for the 7850 but I am not sure if this will fit my budget.
With this computer I plan to play video games and also use it for MATLAB, Solidworks and other 3D modelling software. Is Intel Core i5-3570K a good CPU for this? How risky is overclocking a CPU?
7 answers Last reply
More about what parts upgrade current computer
  1. You GPU is old and needs to be upgraded as well.
    Do this:
    CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($188.79 @ Amazon)
    Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($87.55 @ Newegg)
    Memory: Mushkin Radioactive 8GB (2 x 4GB) DDR3-1600 Memory ($49.98 @ Outlet PC)
    Video Card: XFX Radeon HD 7850 2GB Video Card ($159.99 @ Newegg)
    Total: $486.31
    (Generated by PCPartPicker 2013-03-03 16:36 EST-0500)
    Do this:
    Total: $486.31
    What about my hard drive? It was bought in 2006, will it still be good?
  3. You will need a SATA drive. Your current drive is probably IDE.
    Hmmm, what do you recommend? I am not very computer savvy :P
  5. Any 7200 RPM drive that is SATA.
    Thanks!
    Also, how do I ensure that it all will fit in my case? Are there for example, numbers/symbols that I have to match?
  7. Just looked up your case. Everything will fit just fine.
Homebuilt Computers Systems Product
