Closed
Radeon HD 4850 - Fan Issue
Hello, not sure this is the correct forum. One of the fans of my aftermarket cooler for my Radeon HD 4850 is noisy. This is the fan:
Graphics Card:
Is there an easy way to fix one of the fans? If so, can someone please list a fan that is compatible?
Or would it be easier to just replace the whole cooler? Thanks.
More about : radeon 4850 fan issue
I can't really advise on fixing the fan as I don't have experience fixing them.
You may want to replace the aftermarket cooler with something like this:
However at $40 for a cooler it may be worth just upgrading your 4850 to a bargain card such as a HD 7850 which should provide a considerable performance increase.
Something like this should run pretty quiet and give you good thermals:
Thanks for the advice, but not really looking to drop $180 on a video card. This is for my office rig, so I don't need video performance...just peace and quiet! I am looking at the 7850 for my next gaming rig however.
@unksol: I didn't think about that. I'll take a look inside and see how easy it would be to disassemble.
Related ressources
Best solution
FYI the Radeon 4850 was introduced in June of 2008. It's rated at 1000 gigaflops even, which is surprising for how old it is. That puts it smack between a Radeon 7750 and 7770.
But if it's just an office computer and you never game with it, cut the power wire to the noisy fan. It has a second fan so it won't overheat as it's basically just idle surfing the web or playing video. You can download MSI afterburner and monitor its temperature, afterburner can put a two digit temp icon in your taskbar.
