HElp CAnt chose ANswer it IF u can help ME PLZZZZ(new build )
  • New Build
  • New Build
  • Systems
Last response: in Systems
March 5, 2013 12:46:56 PM
ALL my GAming BROther AND sisters HI
SO im on tight budget AND a Noob NEed some Advice !!
NEed some sugestion
Stuff i got (dont laugh IM migrating froma console)
pentuim 4 ht 630 3.0
ram 2gb ddr2
asus p5ld2
XFX 9600gt 512mb
Cooler master 460 Power suplly AND a MSI casing
think of getting an i3 2100 or higher GHZ
so problem IS
which to select from all MOBOS
asus p8h61-m-lx
gigabyte gah61-m-ds2
intel d61ho
INtel DH61ww
(cnt go to z77 or P68 TIGHT budget ))) ( no other models AVailabitlity issues
SO should Change my graphic card TO 7750 OR 7750 or 6670
i just need to play good titles ON playable FRams
should i go for $gb OR 8gb
should I scrap my gpu and buy ONE or ITS PLAyable :( ((
PLEASE HELp I WAnt u GUYS to BE quick HELPP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
More about : chose answer plzzzz build
March 5, 2013 1:07:09 PM
Stop posting duplicate threads all over the place. :non:
m
l
