Approximate Purchase Date: This week would be nice but I can wait a bit for a good deal
Budget Range: around $800 excluding monitor; dislike waiting for rebates. Can go a bit over that for a good price point.
System Usage from Most to Least Important: Second Life (Firestorm) is the most resource-intensive thing I do, often swapping back and forth between it and Eclipse or OpenOffice or Firefox. Otherwise, not much gaming. Might need MS Office for a year or two.
Are you buying a monitor: Yes, probably 23"
Parts to Upgrade: None, this will probably be a brand new box. My old one is flaky in ways I don't really want to debug (but see below...)
Do you need to buy OS: Yes, I'm on WinXP now
Preferred Website(s) for Parts: Don't care. newegg is fine.
Location: Eastern Mass. I do a lot of my most of my in-person buying at the Cambridge Micro Center.
Parts Preferences: NVidia video card is reportedly best for Second Life.
Overclocking: Never done it before and it makes me nervous. Open to doing it if it's safe.
SLI or Crossfire: Don't think it matters
Your Monitor Resolution: Probably 1920x1080 but open to suggestions
Additional Comments:
- My current PC has a variable-speed fan that changes sound every time I do something on the computer, which I find annoying. I'd rather have one that (a) is too quiet to notice, (b) stays constant, or (c) varies but slowly enough that I don't notice it so much.
- I'm willing to build my own system in order to get an efficient combination of components, but would just as soon buy a pre-built one that someone else has tested, and not have to spend the time and effort and uncertainty.
- I built my current PC - twice, actually - and the current build is kind of flaky. About 1 time in 4 it hangs on the "Windows is starting up" screen; restarting it usually boots. About 1 time in 10 it boots but the network isn't there. Now and then in boots directly to a BSOD. And maybe once a month it just reboots in the middle of something. I don't even know where to start troubleshooting this, but if I can, then upgrading my current system might be an option.
- If I'm buying new, is Windows 8 the way to go, or is there a good reason to buy Windows 7 instead?
- I am a grad student (not at a school with its own store), so could potentially benefit from student discounts
And Most Importantly, Why Are You Upgrading: Second Life is too sluggish even at low graphics settings. Windows XP is too old. Want a more reliable system. Might want to put my current system in another room.
My current system, in case that matters, is:
- Case: Antec Sonata II
- Power: ModXStream Pro OCZ 600W
- MB: Gigabyte GA-78LMT-52P http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
- CPU: AMX FX-4100 Quad-Core
- 4GB RAM? (XP reports 2.75GB)
- WD5000AAKX 500GB HD (with barely 100GB used)
Thanks!
Thanks!
