Help Juiced installation problems
martin
Archived from groups: microsoft.public.windowsxp.games (More info?)
Hi there, I need help
I bought Juiced and cannot install it. During installation I get the error
message:
"Component: loose_files
File: D:/uninstall_icon.exe
Error: An internal error has occurred"
When opening up explorer and clicking on the above file it says:
"not compatible with Win32"
During installation I have all firewalls and anti-viruses deactivated.
Is there a patch I should download? What is the problem here?
Thanks in advance
message:
Thanks in advance
4
answers
Last reply
More about help juiced installation problems
Hi Martin,
"Martin" <Hitt@Ireland.com> wrote in message news:BB9F372E-7466-4DC7-8CFA-FDAFD553B835@microsoft.com...
| message:
| Thanks in advance
That type of error could mean the CD is corrupt... Check the CD
and the CD Player. Clean both using a Cleaning Kit, and check for
scratches on the CD. Try installing the game on another computer,
if the game installs, the culprit is probably your CD ROM drive if it
doesn't install then it's the CD, in which case you need to replace it.
Before replacing the CD, try copying it to your hard drive and then
run the setup / installation program from there. To copy the CD go
to My Computer, Right-Click the CD, Choose "Copy", then Right-
Click on your Hard Drive, Choose "Paste".
Uninstall the game using Add-Remove programs before attempting
to reinstall it. (Start / Control Panel / Add-Remove Programs).
Here are three basic troubleshooting steps which I recommend:
1. To see if it's a software conflict: Temporarily disable Startup
programs one at a time, starting with Firewall, Antivirus, and ad
blockers using: http://new.jtsoft2001.com/windows/startup.php
You can lookup what a program does before you disable it here:
http://www.sysinfo.org/startuplist.php
2. Run a virus scan at: http://housecall.antivirus.com Afterwards
Download & Run Spybot from: http://security.kolla.de and/or
Adaware (www.lavasoftusa.com) to remove any Spyware/Adware.
3. Click My Computer / Rightclick the Drive & Choose Properties
/ Run the "Disk Cleanup..." / Next Click the "Tools" Tab and run
the "Error-Checking" and "Defragmentation" utilities.
If nothing including those 3 steps have resolved the problem so far,
here's more basic troubleshooting steps and information including:
The Safedisc patch
How to check CD for imperfections, and
How to Disable Virtual CD rom drives which is described at:
http://tinyurl.com/2387c (EA General Support Page) and also:
How to Troubleshoot Disc-Reading Issues
Error Messages That May Be Caused by Disc-Reading Issues
Troubleshoot Error Messages
Examine the Disc
Clean the Disc
Test the Disc in a Different Drive
Clean the Drive
Test Disc Read with Copy or Xcopy
Quit Unnecessary Software
Switch the Drive Controller to DMA Mode, and
How to Troubleshoot DVD Error Messages is available in this
MS Article: http://support.microsoft.com/default.aspx?kbid=321641
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/default.aspx?scid=sz;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________ -
Hi Jimmy S.,
The installation worked on another computer. I out of curiosity tried
burning a CD. It was here that Nero told me that my InCD and burning rom
needed updating. After downloading the CD Rom updates, the game was installed
succesfully.
Thanks for your advice though.
Martin
"Jimmy S." wrote:
> Hi Martin,
> | message:
> | Thanks in advance
> The Safedisc patch
> Examine the Disc
> Clean the Disc
> Clean the Drive
Hi Martin,
I'm happy to hear that everything worked out for you! :-)
Cheers,
Jimmy.
"Martin" <Hitt@Ireland.com> wrote in message news:AD655CBA-C8C2-4422-A7B2-BE86320FC82F@microsoft.com...
| Hi Jimmy S.,
| succesfully.
| Martin
| "Jimmy S." wrote:
| > Hi Martin,
| > | message:
| > | Thanks in advance
| > The Safedisc patch
| > Examine the Disc
| > Clean the Disc
| > Clean the Drive
hi, im very new to this so i dont even now how to start my own topic so
i have used someones reply sorry.
i am having problems with the installation of juiced, i can install the
game and then it loads but an error screen appears, with the send error
report option, but then it says juiced.exe has encounted a problem and
has to close i have tried installing it on two different pc's and a
laptop but still no result, and this is the second game as i have taken
it back to the shop and got a different one. i am completly confused,
somebody please help.
cheers marc.
Jimmy S. wrote:
> Hi Martin,
> | message:
> | Thanks in advance
> The Safedisc patch
> Examine the Disc
> Clean the Disc
> Clean the Drive
Related Resources
Windows XP
Related Resources
- Error when loading a game help please
- Win32 Cabinet Self-Extractor error
- FarCry Installation Error 1628
- `.hlp file is not a Windows Help file' Error
- Error message problems
- SP 2 install failing with odd write error
- Error Message during Installation
- Please help - Generic Host Process for Win32 error
- File download & installation error?
- Generic Host Win32 error... please help!
- LEXMARK X125 PRINTER INSTALLATION COMPONENT TRANSFER ERROR
- Unable to install fax service - Library error
- Error in Installation of SP! of Windows 2003
- Microsoft Generic Host Process for Win32 Services Error and SVCHost.exe using 1
- Keyboard error due to patch
