C customcoumputor Honorable Jan 12, 2013 39 0 10,530 Mar 6, 2013 #1 Is every water cooling compatible with a Corsair Carbide 300R case if not please tell me which ones are compatible
g-unit1111 Titan Moderator Jul 27, 2011 42,548 824 104,940 Mar 6, 2013 #2 It should house up to a 2 x 120 mm fan radiator so as long as it meets those specs you're good. You really don't need liquid cooling though - you should stick with air. Upvote 0 Downvote
