Hi, I've got four year old Alienware laptop, and it's time for upgrade. I need advice if I didn't miss anything, and if I did some unreasonable decisions.
Approximate Purchase Date: as soon as I've made up my mind on the parts. Not later than in 2 weeks.
Budget Range: ~1500Eur (at least that's what this rig adds up to).
System Usage: mainly gaming (Arma 2, Arma 3, WOT, Planet Side 2, CIV5 maybe Battlefield 3 etc.) maybe some screen recording and video editing.
Are you buying a monitor: Not at this moment. I've already got Dell U2312HM, but considering buying 27" 120Hz Yamakasi Catleap in near future (different budget).
Preferred Website(s) for Parts: Skytec.lt or 1a.lt
Overclocking: Yes, as much as hardware will allow.
SLI or Crossfire: SLI
Your Monitor Resolution:[/n] Currently 1920x1080. Catleap would be 2560x1440.
Additional Comments: No need for bling, would prefer as quite as possible.
That's what I've researched and picked so far:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
Motherboard: Gigabyte GA-Z77X-UD3H ATX LGA1155 Motherboard ($144.99 @ Newegg)
Memory: Kingston Black 16GB (2 x 8GB) DDR3-1600 Memory ($87.00 @ Amazon)
Storage: Intel 520 Series Cherryville 240GB 2.5" Solid State Disk ($239.99 @ Newegg) (already have this in current laptop, will keep it for the build. Will buy HDD later if my old ones won't be enough).
Video Card: Gigabyte GeForce GTX 670 2GB Video Card (2-Way SLI) ($369.99 @ Newegg)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($109.99 @ Amazon)
Power Supply: Corsair Professional 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($149.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($18.98 @ Outlet PC)
Total: $1710.90
Stuff bothering me:
1. Is this cooler enough, or do I really nead Noctua NH-D14 or Corsair H100i?
2. I've chosen this RAM to match mobo and not to be extra tall, but otherwise I have no clue what would be more appropriate. I want 8GB sticks (kind of future proof).
3. PSU seems to be old model. Should I be bothered, or 80+Gold is all I need to know. I'm a bit disappointed that it is single rail. Not very safe. Is it of appropriate size, or should I choose 750W instead? If I decide to go with single gfx card, I'd like to have an option to add another in the future without upgrading PSU.
4. Gfx - I want Nvidia, as Arma and Planet Side uses PhysiX. Would two of GV-N670OC-4GD fit on the motherboard? Would I need 4GB of VRAM for 2560x1440?
5. Would everything fit into the case?
Thank you in advance!
Total: $1710.90
Stuff bothering me:
