Nzxt 410 phantom problem
  • Homebuilt
  • Computers
  • Power
  • Systems
Last response: in Systems
March 6, 2013 7:56:53 PM
Well, I have built a computer (Specs at the bottom) and everything works! But the button to turn on the system won't work. According to the manual, I plugged it in right. So I don't know what is going on. And the only way my system will turn on is when I click the mobo power button. It works fine then, but I don't wanna have to touch the mobo power button to turn on my new gaming comp. :p
http://pcpartpicker.com/p/D7AP
More about : nzxt 410 phantom problem
March 23, 2013 9:46:49 PM
Will there are 3 possibilities, the "power" switch is a momentary contact type of switch if you have a OHM meter you can connect it to the switch plug in (disconnect it from mother board first) and hold the power swith done the OHM meter will read continuity if it does the switch is good, next the 2 pins that the switch plug into on the mother board (with the every thing else but the switch pluged in) cross the 2 pins momentary if the system urns on and the above test on the switch is good then the switch is not pluged in correctly.
Ranco58
m
l
