Hello,
SAPPHIRE 100352-2L Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Intel Core i5-3470 Ivy Bridge 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Rosewill CAPSTONE Series CAPSTONE-650 650W Continuous @ 50°C, 80 PLUS GOLD Certified, Single 12V Rail, ATX12V v2.31 / EPS12V v2.92, SLI Ready, CrossFire Ready, Active - PFC Power Supply
Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - OEM
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
LITE-ON DVD Burner - Bulk 24X DVD R 8X DVD RW 12X DVD R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
It is also with this monitor ASUS VS208N-P Black 20" 5ms LED Backlight Widescreen LCD Monitor 250 cd/m2 ASCR 50000000:1.
Say I'm running Crysis 3 at around high settings with a med to high resolution. Will the 650 watt in the above build be enough? If not, how much power should I get?
Thanks.
Thanks.
