Solved
New System Build Around $800
Approximate Purchase Date: By the end of May 2013
Budget Range: Around $800 (not including Harddrive, monitor upgrades, optical drives, case, and power supply)
System Usage from Most to Least Important: Office, browsing internet, listening to music, watching movies, editing photos, gaming.
Are you buying a monitor: Not at this time. Currently have a dual monitor set up with older lcd monitors.
Parts to Upgrade: CPU, RAM, MOBO, OS, GPU
Do you need to buy OS: Yes - Windows 8 Pro (32bit or 64bit?)
Preferred Website(s) for Parts: Newegg, microcenter, tigerdirect
Location: City, State/Region, Country - Michigan, metro detroit area
Overclocking: No
SLI or Crossfire: ?
Your Monitor Resolution: 1024x768 - dual monitor
Additional Comments: Trying to build a more efficient and quieter PC
And Most Importantly, Why Are You Upgrading: Have a year left of XP security support and no longer interested in computer gaming.
I am looking to upgrade my Q6600 Dual Core Build from 5-6 yrs ago that I used to play WoW heavily before being banned (for the 3rd time) as well as StarCraft.
I am currently using the following:
OS: Windows XP Pro
CPU: Q6600 Quad with GO Stepping
Mobo: Asus P5K Deluxe
GPU: BFG GeForce 8800 GTS OC2 320MB GDDR3
RAM: 4gbs of Corsair DDR2 XMS2 6400C4
I am upgrading to the following:
OS: Windows 7 Pro or Windows 8 Pro. I do not care for the touchscreen so leaning towards 7
CPU: i5-3570K ($190)
http://microcenter.com/product/388577/Core_i5_3570K_34GHz_LGA_1155_Processor
Mobo: Asus P8z77-V LGA ($145 if purchsed with CPU)
http://www.microcenter.com/product/386886/P8Z77-V_LGA_1155_Z77_ATX_Intel_Motherboard
GPU: **NEED SUGGESTIONS**
Ram: **NEED SUGGESTIONS** Was looking at the CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML8GX3M2A1600C9W
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233199
Any suggestions or thoughts?
THANK YOU!!
1 answer Last reply Best Answer
More about system build
  1. Best answer
    You don't need a gpu if don't want to play games, the motherboard and the igpu supports a dual monitor setup, the igpu of the i5 is more than sufficient for your needs.
    Cheaper ram here : http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
    or http://www.amazon.com/dp/B004QBUL1C/
    As for the os, get the windows 7 home premium 64 bits, since you'll have 8GB of ram, you'll want the 64 bits os, since you can't use more than 4GB with 32 bits.
New Build Systems Product
