Solved
Building First Computer (Seeking advice on build)
Last response: in Systems
March 8, 2013 2:13:20 AM
Hello everyone I'm looking to build a new pc and need some advice on the build that I have chosen. I've done a lot of research but I figured I would check and ask advice from the forums before I went and bought anything. Any advice or revisions are welcome. Thank You.
http://pcpartpicker.com/p/Hy0O
Approximate Purchase Date: This week
Budget Range: ($750-$800 after shipping and rebates
System Usage: Mostly Gaming
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg
Location: City, State/Region, Country - Joplin, Missouri
Parts Preferences: by brand or type Amd Cpu and Gpu
Overclocking: In the Future
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
March 8, 2013 2:26:55 AM
your build is actually really good for first build, good job.
if you want you can get a cheaper (still good) motherboard and maybe get a lesser case (but that case is great btw) you can upgrade your CPU
March 8, 2013 4:12:31 AM
Do you have any suggestion on the motherboard?
Best solution
March 8, 2013 4:46:20 AM
That is a good motherboard I would really not recommend getting cheaper one unless you can find that board for a cheaper price. You could save some money by going with a 7850 instead of a 7870 but I have not used any mid range cards so I do not know how much of a performance loss you would have and even at that you would only save about $30 dollars so weather it would be worth would be up to you.
Over all you have a good setup already I would not really change anything. You have a rig that you will be happy with and that is the most important part of building a rig.
March 9, 2013 3:39:12 AM
Best answer selected by Alumbaugh31.
March 9, 2013 3:39:46 AM
Thank you everyone for your comments and suggestions. I really appreciate it.
