Bluetooth problem
  • Nokia
  • Phones
  • Bluetooth
Last response: in Brands
July 18, 2005 4:13:09 AM
Archived from groups: alt.cellular.nokia (More info?)
I have a nokia 6230 and I am trying to connect it to my PC by Bluetooth.
The phone and the PC both recognise each other, but I after I try and pair
them I enter the code and then get an error saying; paring and comm. failed
then the mobile crashes. If I click pair on the phone it just says failed.
Am I too assume that my phone might have dodgy firmware, or is there a
reason for it to crash on Bluetooth usage?
XBL : D0C RAY
We'll be Gunning for you
More about : bluetooth problem
Anonymous
July 18, 2005 11:33:19 PM
"KerplunKuK" <kerplunk@greenday.freeserve.co[dot]uk> wrote in message
news:3k06v5Frpka3U1@individual.net...
failed
failed.
I too had this problem with my 6230. Tried using different dongles to no
avail. Ended up buying a usb multi card reader and have given up with the
dongle(s) completely.
Netty
Anonymous
July 19, 2005 1:44:43 AM
What adapter are you using for your pc?
> XBL : D0C RAY
July 19, 2005 7:08:01 AM
BT500 USB Bluetooth Dongle
XBL : D0C RAY
July 20, 2005 1:18:44 AM
try to uninstalled your Nokia PC Suite and bluetooth driver and reinstalled
it back.
when it prompt to synchronise......your phone should receive a prompt stated
your "computer name" on the phone screen from your PC and your acknowledge
yes.Ensure that on the Task Bar below on your PC show have an mobilephone
icon.If you move your cursor directly on the icon the dialog message should
stated
Nokia PC Suite and Nokia 6230 connected via bluetooth
i hope this help..coz i'm using a Nokia 3230 and Blutonium Wireless Adapter
without problem
news:3k35i4Fsecc1U1@individual.net...
> XBL : D0C RAY
July 23, 2005 6:04:07 AM
When I try and connect my 6230 to my PC via bluetooth dongle I get an error.
The error says;
Paring and conn. rejected for security reasons
This appears after inputting the correct bluetooth passkey. I have tried
uninstalling the bluetooth and reinstalling that makes no difference and I
am using the latest drivers.
Any ideas?
XBL : D0C RAY
Anonymous
July 23, 2005 6:04:08 AM
news:3kdj2kFt9lf3U1@individual.net...
> error.
> The error says;
> Any ideas?
Which Bluetooth drivers are you using? Sometimes it helps if you look for,
and then delete, any existing pairings in the phone and in the PC.
Take control of your Nokia phone with LogoManager
http://www.logomanager.co.uk
July 23, 2005 7:01:23 AM
> look for, and then delete, any existing pairings in the phone and in
> the PC.
No pairings in the PC or phone. Drivers are bluetooth 12 zeevo, BT500 1.2.
XBL : D0C RAY
Anonymous
August 17, 2005 12:10:21 AM
On Sat, 23 Jul 2005 03:01:23 +0100, "KerplunKuK"
>> the PC.
Not sure if it's the same chipset but I have a Sitecom CN500 that had
to have a security code written to it in order to be able to use the
latest drivers.
Alan
Take DogForAWalk before replying by e-mail
Anonymous
August 17, 2005 12:55:54 AM
Yeah my 6230 did this (including the reboot) when I tried to pair it with my
ipaq. It paired fine with my PC.
I needed an update for the ipaq because it was using an earlier
authentication method that the 6230 wouldn't accept. Once I had updated the
ipaq it paired fine.
I'd go looking for updated drivers for your bluetooth card I reckon.
> error.
> The error says;
> Any ideas?
> XBL : D0C RAY
Anonymous
August 17, 2005 12:58:43 AM
Here's an article about ipaqs - but it explains the issue.
http://h18007.www1.hp.com/support/files/HandheldiPAQ/us...
> error.
> The error says;
> Any ideas?
> XBL : D0C RAY
