***i posted this elsewhere on the forum but its not getting much attention because it doesnt pertain to the topic i posted under anymore. so ill post here to cover all bases.***
first build ever:
CPU: AMD FX-6300 3.5GHz 6-Core Processor
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard
Memory: G.SKILL Value 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C11S-8GNT
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Sapphire Radeon HD 7850 2GB Video Card
Case: Antec Three Hundred Illusion ATX Mid Tower Case
Power Supply: CORSAIR Builder Series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
Operating System: Microsoft Windows 7 Ultimate Full (64-bit)
Mouse: Logitech G9x Wired Laser Mouse
Monitor: HP 2010i 20" widescreen lcd 16:9
Optical Drive: HP DVD-RAM GH60L
every now and then the speakers will make the "burrrrrrr" noise and the screen will stutter/lock up for a second.
screen will stutter every few seconds. this isnt a constant occurrence but occasionally happens and once it does it keeps happening until i restart.
NOTE:
not overclocked.
catalyst and drivers up to date. version 13.1 found here: http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
this occurs if i do anything graphic intensive. such as streaming video or playing games.
speedfan temps are all under 60C (gpu and cpu get up to about 59c/60c under load while playing bf3)
everything in bios is set to auto/default
help
first build ever:
NOTE:
not overclocked.
help
