Tom's Hardware > Forum > Audio > Audio Technology > sonic benefit of a Tubed- over SS Power supply
Forum Audio : Audio Technology - sonic benefit of a Tubed- over SS Power supply
Archived from groups: rec.audio.tech (More info?)
Hi, I am a newbie. I am interested in getting a Line-stage tube preamp for
teaming up with my SS amp. The Line-stage tube preamp offer 2 version
of power supply- one is SS the other is tube . I wonder would there be
any sonic advantages of tubed- over the SS power supply ? Your
explaination and opinion is highly appreciated and thanks in advance
Simon
Sponsored Links
> preamp for teaming up with my SS amp. The Line-stage tube preamp
> offer 2 version of power supply- one is SS the other is tube . I
Exactly which products are you investigating? I can find several products
that fit your general description.
> wonder would there be any sonic advantages of tubed- over the SS
> power supply ?
Depends on the implementation, which is why I'm asking for more specifics. .
I can see some advantage of DC power for the tube filaments, which
practically presupposes a power supply that it is at least partially solid
state.
Reply to Anonymous
Thanks Mr.Krueger. I am investigating the Tubed and the SS Power supply
namely: the PSIt and the PS1 by Mapletree Audio Design, here is the link
http://hollowstate.netfirms.com/
I am interested in either the PSIt or PS1 for the Line2A tube preamp application.
Your opion and suggestions is highly appreciated and thanks in advance
Simon
Reply to Anonymous
> supply namely: the PSIt and the PS1 by Mapletree Audio Design, here
> is the link http://hollowstate.netfirms.com/
> application. Your option and suggestions is highly appreciated and
> thanks in advance Simon
I have to admit that my CJ tubed preamp has a SS power supply. But, I like
the idea of a slow application of B+. It's too bad they didn't put a time
delay in their SS power supply. The tubed power supply does use SS rectifier
and regulator for the filament supply, which is a big advantage.
Reply to Anonymous
Thanks again,Mr.Krueger. Do you think the PSIt would work better than
the PS1 (on the Line2A preamp application)?
Simon
Reply to Anonymous
- 0 +
"Arny Krueger" <arnyk@hotpop.com> wrote in message news:<W6GdnUvlp6iJLiDdRVn-ig@comcast.com>...
Waiting for the filament to heat up enough to start boiling electrons
off the cathode to be attracted to the plate sort of counts as a slow
application of B+, doesn't it?
Reply to unitron
>> I like the idea of a slow application of B+. It's too bad they
>> didn't put a time delay in their SS power supply. The tubed power
>> supply does use SS rectifier and regulator for the filament supply,
More than sorta. It just does! I find it hard to believe that there aren't
more SS power supplies for tubed equipment that have a time delay on the B+.
Some of these devices even have separate transformers for the B+ which means
that a SCR on the primary side could provide the required control function.
Reply to Anonymous
- 0 +
"Arny Krueger" <arnyk@hotpop.com> wrote in message news:<X4ydnU8YuZCdkCLdRVn-gQ@comcast.com>...
If you've got B+ on the plate but no heater current, can the tube suffer harm?
Reply to unitron
>>>>> But,
>>> electrons off the cathode to be attracted to the plate sort of
>>> counts as a slow application of B+, doesn't it?
>> aren't more SS power supplies for tubed equipment that have a time
>> delay on the B+. Some of these devices even have separate
>> transformers for the B+ which means that a SCR on the primary side
> suffer harm?
Yes.
http://www.svetlana.com/docs/TechB [...] talk1.html
Reply to Anonymous
>>>>>>But,
>>suffer harm?
>Yes.
>http://www.svetlana.com/docs/TechBulletins/techtalk1.html
Cathode stripping is completely misunderstood and misstated in that article.
A reference where the effect is at least understood and sorta well explained
is:
http://www.vaxxine.com/phil/scopes/arnoud/weyer.txt
Reply to Anonymous
There are 1033 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
