Power Supply for Sapphire HD 7850 2GB OC Edition
Hi
I need help in selecting a psu for my system. minimum how many Watts of power supply do i need to run my system with graphic card overclocking. Here r my Specs:
i7 3770K
Gigabyte Z77X-UD3H
2 TB hdd
250 Gb hdd
8 GB Ram
Samsung Optical Drive
Currently using a Cooler Master 400W Psu.
Thanks.
9 answers Last reply
More about power supply sapphire 7850 edition
  1. Reference here:
    http://forum-en.msi.com/faq/article/power-requirements-for-graphics-cards
    Normal 7850 requires a 500W psu with 21 amps on the +12V rail. I'm guessing OC edition might need 10% more, so a 550W or better psu with at least 24 amps on the +12V rail should be safe.
  2. uchihaobito said:
    Hi
    i7 3770K
    Gigabyte Z77X-UD3H
    2 TB hdd
    250 Gb hdd
    8 GB Ram
    Thanks.
    Your ok with the psu youve got! Unless you have a half decent graphics card which i didnt see listed in your specs mate. If your just using the onboard graphics on your cpu then your fine.
  3. For a single graphics card like 7870 you'd be fine with a xfx pro 550w http://www.ebay.co.uk/itm/XFX-Pro-550W-Core-Edition-PSU-Bronze-Power-Supply-P1-550S-UKB9-/150971230719?pt=UK_Computing_PowerSupplies_EH&hash=item23269629ff £52 is a good price! If your wanting to crossfire then id get a more powerful psu , but the xfx will be well ok 4 what youe after.
  4. Great this psu has a lifetime warranty right? i dont know if i will get this psu since i live in india. i will have 2 check with shop dealers.
    What about this one on ebay india. http://www.ebay.in/itm/CORSAIR-VX550W-Watts-SMPS-Power-Supply-VX-550W-BILL-WAR-/200869163710?pt=LH_DefaultDomain_203&hash=item2ec4bc32be
  6. Flipkart.com this site does provide a lot options but cannot choose which one will be right. can u go thru d site and recommend a psu. my budget is Rs 3500. i dont how 2 copy d link sorry. this is d last time i promise. Thanks
    This one will 100% be fine for you friend http://www.flipkart.com/cooler-master-thunder-500w-500-watts-psu/p/itmdbm7fefnpygyn?pid=PSUDBM7EDH7YSFTZ&ref=9f498f73-84e6-4eb9-8ca0-987656533453&srno=m_1_1&otracker=from-search&query=psu.
    Use this program to check how much power your system is using friend. http://extreme.outervision.com/psucalculator.jsp . Youll know for definate what wattage your system is using.
    Heres an easy online checker. http://www.extreme.outervision.com/psucalculatorlite.jsp
Graphics Cards Power Supplies Sapphire Graphics Product
