G
Guest
Guest
Help Needed;
Im a newbie , built my first PC in the last two days, as a test run before i buy components for a 2Gig+ Machine.
Specs:
Gigabyte GA-586STX MoBo ATX
Generic ATX Mid-Tower Case
128MB Pc133 SDRAM
Mitsumi 5400 3.9GB HDD
AMD K-6 200 CPU
52X CD-ROM
Floppy
U.S. Robotics Sportster 33600 Fax modem
STB Nitro graphics Card
and an undetermined Sound card.
My problem is that the Riser Plates supplied with the case i bought dont fit the Motherboard. Both serial ports, the parallel port, Ps2 ports, are all in a single row top to bottom, in this order: Serial, Ps2 Mouse, Ps2 Kboard, Parallel, Serial. where can I find misc ATX Case Riser Plates??????????
Thanx
Specs:
128MB Pc133 SDRAM
AMD K-6 200 CPU
52X CD-ROM
Floppy
Thanx
