Hi guys hope someone could help me out as I'm in a pickle somewhat. I've been build rigs for a while now and this is the first time that I encountered a build where the graphics won't work somehow when inserted into the motherboard.
BTW this build is for a client of mine and was ecstatic at first that I get to build an SFX gaming rig.
The parts that I used are:
Silverstone FT03 Mini Case
Silverstone ST45SF-G 450W 80+Gold PSU
Silverstone SOD02 DVD ODD
Intel Core i5 3570 (my client opted for the non-K as his budget was at its limit)
Asrock Z77e-ITX
Corsair Vengeance LP 8GB Kit 1600 CL9
Corsair H60
2x OCZ Vertex 3 60GB
EVGA GTX660Ti 3GB FTW + Backplate
MS Windows 8 Pro
Setting up the system was surprisingly challenging due to the small workspace since I'm used to building big bulky rigs. The smallest that I got the chance to work on before this was the Bitfenix Prodigy next to the Silverstone FT03.
Anyway during the first run nothing showed on my LED/LCD screen..Just displayed "no signal" that floats around the vast black space. I tried using both the HDMI port and one of the DVI port to no avail. Made it to work at some point twice but the system just reboots itself after a few seconds then I'm back to the "no signal" sign which became permanent..
I removed the graphics card and used the mobo's DVI port and everthing worked fine. I inserted the graphics card back in and again "no signal". Removed it and everything was normal, so I thought that the card might be faulty.
The next thing that I did was again removed the graphics card and inserted it to my own FT03 rig (Asus Maximus V Gene, Intel Core i5 3570K @4.2, Corsair Vengeance LP 16GB 1600 CL9, Corsair AX650, Crucial M4 128GB) and it worked! I suddenly thought that it might be the board itself or the PSU so i put everything back in and inserted my bro's old EVGA GTS450 FTW and everything worked just fine..swapped the other 6pin pci power for the graphics card with the other and still it worked.
I was scratching my head by then and thinking WTH was wrong with the build that I was doing. Again I removed my client's graphics card out of my rig, reset everything to how it was with the Mini and powered it back on with all fingers crossed. Sadly still no go.. and now I'm stuck and don't know what to do..
Hope someone could help me out..I can't RMA parts that seems to be working..
Asrock Z77e-ITX
Corsair H60
MS Windows 8 Pro
