Tom's Hardware > Forum > Home Cinema Equipment > Ptv Replaytv > Is it possible, crossover cable to computer with cable mod..
Forum Home Cinema Equipment : Ptv Replaytv - Is it possible, crossover cable to computer with cable mod..
Archived from groups: alt.video.ptv.replaytv (More info?)
I have a broadband cable modem hooked to my computer. Is it possible
for me to install another network card, and use a crossover cable from
the new network card to the replaytv? I want this to be my means of
updating the replaytv, plus transfer files via DVarchive.
Any advantages/disadvatages to doing this method as opposed to buying a
router and hooking the cable modem to the router, then splitting to the
computer and replaytv? If the crossover cable will do this same, then
I can save money and not buy a router.
Please give me any suggestions/thoughts. Thanks.
Sponsored Links
I would just buy a router, they are $40 or so.
Simplify your life whenever possible. You will thank yourself later.
Reply to Greg
gfretwell@aol.com (Greg) shaped the electrons to say:
Yeah - a cheap home gateway will generally still have a firewall and
DHCP server, and it consumes a hell of a lot less power than a PC. It
is also easier to setup then sticking another NIC in the PC and then
setting up connection sharing in Windows.
Even a home gateway with built in 11g support and more features runs
around $100.
-MZ, RHCE #806199299900541, ex-CISSP #3762
<URL:mailto:megazoneatmegazone.org> Gweep, Discordian, Author, Engineer, me.
"A little nonsense now and then, is relished by the wisest men" 508-755-4098
<URL:http://www.megazone.org/> <URL:http://www.eyrie-productions.com/> Eris
Reply to Anonymous
> around $100.
Bought one a few weeks ago (Netgear MR614 with 11g) for $19.99 after
rebate. Not much more than a NIC!
Reply to Anonymous
Possible yes, but given that configuration I think I'd spend a few
dollars more and install a router, A 2nd LAN card (NIC) will run you 10
to 20 bucks, When on sale a low end D-link or Linksys router will run
you 20-40 bucks, Not that much different, and my DWL-650 is wireless, So
it runs the laptop no matter where in the house I am as well as two
desktops (Well mini-towers) and the Replay. Laptop wired if it's in
it's DOC, wireless when undocked.
Reply to Anonymous
runs
> > around $100.
If I use wireless, wont transfer speeds be considerably lower than a
wired setup?
Also, what will hook up to the Replaytv if I use a wireless router?
Reply to Anonymous
On 22 Sep 2004 05:40:56 -0700, "SW Monkey"
<google311.50.spydermonkey@spamgourmet.com> wrote:
>runs
>> > around $100.
>wired setup?
They will. This can keep streaming from working. Use a (much simpler)
wired network if possible.
94 days until the winter solstice celebration
Mark Lloyd
http://notstupid.laughingsquid.com
Reply to Anonymous
"SW Monkey" <google311.50.spydermonkey@spamgourmet.com> shaped the electrons to say:
>wired setup?
Yes.
To use wireless you'd have to get a Wired-to-WiFi bridge to connect to
the RTV's wired Ethernet port.
Reply to Anonymous
While wireless will work using a bridge (typically a $70 item) at the
RTV end, a wired connection is far better. My point was that the
wireless router, which includes wired ports as well, is almost as cheap
as a NIC now. You may not need the wireless at all or you could use it
for your laptop or security cameras.
At my other home I had to use wireless to reach the RTV as there were
no practical options for running cable. It does do daily updates and
show sharing but I haven't tried tried any streaming.
>>> around $100.
> wired setup?
Reply to Anonymous
On Wed, 22 Sep 2004 19:11:38 GMT, "BruceR" <brNOSPAM@hawaii.com>
It may or may not work. Wireless links are often slower than what
streaming requires. The stated speed drops off quickly with distance
(wireless link) and wireless has higher overhead. There should be more
chance of streaming working with "g" wireless.
>From:SW Monkey
>>>> around $100.
>> wired setup?
Mark Lloyd
Reply to Anonymous
There are 965 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
