I just finished putting the RAM/VRM heatsinks on my GTX 680 classified. Everything was done correctly to my knowledge and I even had to cut some as there were not enough in the box for the large card on some of the smaller compnents. I wads unable to get the insulation tape/film to stick onto the card and the glue is now drying on the sinks I have put on. Is this a major problem and do I need to remove these asap and put something there? The reason I cant get it to stick is because it wont come off correctlty and bits of paper are stuck to the adhesive side.
If I need to remove them and put something there, what can I use instead of the film they provided and how do I get the sinks off with the adhesive TIM in place? I can't afford to short this card. Please help, ty.
