Okay so i can't get any DVI output on several different screens i tried. Here are the symptoms.
Powers up, cpu fan spins, case fan spins, case LED works, GPU fans spin, GPU LEDs work. I get no beeps or visual output.
I then took every component out of the case and assembled the mobo, 1 ram stick (also tried with two at one point), cpu was already on there, and put the grpahics card on that, but still the same problem: i get no beeps or visuals.
here is a list of my components.
GPU: Asus 560 ti 900mhz overclocked model
PSU: Corsair CX 600
Mobo: Asrock 970 pro 3
RAM: Corsair Vengeance 1600mhz
sidenote: I have no onboard graphics on this mobo so i connect a DVI cable from the GPU (tried both slots) to the screen and the screen just displays " NO DVI SIGNAL " and it seems to be the same for other screens too so my guess is that either the Mobo or GPU is damaged... Anyways i desperately need some help please!
PSU: Corsair CX 600
