Can you run a 350 watt build on a 480 watt power supply?
Hi, I will be build my computer sometime soon, however I am not sure on this. If anyone could be of assistance, I would greatly appreciate it! I need to know if I can run a 350 watt build on a 480 watt power supply? Will it make any difference in performance, or is there any risks? I have posted a link to my build list below, please take a look if needed.
Thank you in advance,
Daniel D.
12 answers Last reply
More about watt build watt power supply
  1. It is recomended to have a larger power supply then what your build requires so it will run without any trouble!
  2. By the way, where is your build? No link posted below.
    Sorry I was in a hurry, lol.
    http://pcpartpicker.com/p/ICmh
  4. http://www.newegg.com/Product/Product.aspx?Item=N82E16817207018
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
    if you may want more gpu in future the 550W XFX is a great psu. Wattage is not the only factor when looking at psus - current on the 12V rail is very important. The XFX supplies are good quality and are very quiet - highly recommend them.
    -Bruce
  5. What is this build for? If it is for gaming, it is underpowered. I suggest this.
    PCPartPicker part list: http://pcpartpicker.com/p/IDk8
    Price breakdown by merchant: http://pcpartpicker.com/p/IDk8/by_merchant/
    Benchmarks: http://pcpartpicker.com/p/IDk8/benchmarks/
    CPU: AMD FX-6300 3.5GHz 6-Core Processor ($119.99 @ Microcenter)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
    Motherboard: MSI 970A-G46 ATX AM3+ Motherboard ($79.99 @ Newegg)
    Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory ($42.99 @ Newegg)
    Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($59.14 @ Amazon)
    Video Card: Sapphire Radeon HD 7870 XT 2GB Video Card ($234.99 @ Newegg)
    Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Newegg)
    Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($59.99 @ Newegg)
    Monitor: Hannspree HL229DPB 21.5" Monitor ($99.99 @ Newegg)
    Total: $777.06
    (Generated by PCPartPicker 2013-03-09 18:53 EST-0500)
  6. I already have all of my parts except for the video card and monitor. I can't change now.
    I would spend less on the monitor and get a 7850.
    Do you have a link?
  9. I will be using this build for work, home-use, and gaming.
  10. Nobody told him the psu he has only can deliver 16A on the +12 rail ? That's actually less than 200W, the cpu itself is 125W(will also be fed on the +12v rail), the card will be ~100W(7850), even with the 550 ti, you'll probably will reach more than 192W in load with cpu+gpu, that psu is junk, most junk psus will damage the components when overloaded.
    I recommend getting a decent psu, an throw away the one that came with the case, never cheap out on the psu.
    Actually you just need a 400W psu for the 550 ti, but a decent one.
    You can find cheap decent psus like the Corsair CX430, Antec VP-450, Antec Neo Eco 400C, XFX 450 Core Edition, Seasonic 430W, Roswill Green 530W.
    Then look for a cheap monitor in neweeg, there's some for less or about 100$.
    For a Card either the 650 ti or 7850 if possible.
    Same price as your monitor and card, with new psu, gpu and monitor : http://pcpartpicker.com/p/IDSX
    This one can deliver the full power : http://www.hardwaresecrets.com/article/Antec-VP450-Power-Supply-Review/1487/9
    http://www.hardwaresecrets.com/article/Antec-VP450-Power-Supply-Review/1487/11
    Thank you very much, I will take your advice on this!
Homebuilt Power Supplies Build Systems Product
