Archived from groups: alt.cellular.nokia (
More info?)
Not without looking at it really.
I changed to a 3410 and never looked back as this is the best of the 3330
and 3310 with some extra bits added in.
The firmware on 3330 is very buggy. Whereas 3410 is quite stable and works
with LM much better.
(They should have released more updates, this phone was dropped on updates
very early on - very bad actually).
I suggest you buy a 3410 and unlock it while you still can.
You cannot mess with eeproms due to the IMEI UK laws - and even if you did,
is probably not necessarily the cause.
http://www.noklocked.btinternet.com/
<pjhayden1@gmail.com> wrote in message
news:1121969715.228415.96750@z14g2000cwz.googlegroups.com...
> My Nokia 3330 went to "CONTACT SERVICE". I re-flashed it using KNOK95
> and 3330F450C.FLS. but it will not ring or vibrate on an incoming call.
> The screen indicates "calling" and I can answer and speak ok. Also all
> the other features on the phone are working ok.
> Can anyone offer me some help?
