I am trying to build a computer to render short standard definition videos and burn them to a DVD. I hoping to be able to get a 5 minute video rendered and burned in 15-20 minutes tops. I really have no preference on hardware brands . Im not really sure were to start. im hoping you guys can give me some advice. What would you build if you had the same project? I would appreciate any help you could give.
Approximate Purchase Date: e.g.: this week (the closer the better)
Budget Range: $1100
System Usage from Most to Least Important: Rendering Dvd burning
Are you buying a monitor: No
Parts to Upgrade: new build
Do you need to buy OS: Yes planning on windows 7
Preferred Website(s) for Parts: dont care
Parts Preferences: Intel CPU
Overclocking: Yes
Budget Range: $1100
Overclocking: Yes
