Hi Guys,
I need your help.
I was using XFX HD 5670 and got damaged in warranty so XFX gave me a HD 5770 graphics card.
As you all know 5670 doesn't require any external power but 5770 do have a 6 pin slot.
I have read some where that 5770 and 6770 can run without using external power.
They can draw the power itself from PCI-e slot. Is it rue or not ???
Please suggest me whether they can run without using external power or not ??
Also if they do require external power. I have a local brand (intex) 450W PSU, can I use it by purchasing 6 pin to 4 pin cable.
PC Specs:
Intel i3 2120.
Gigabyte B75M-D3H
1 TB seagate HDD
Guys please advice asap.
Thanks
I need your help.
PC Specs:
Intel i3 2120.
Gigabyte B75M-D3H
1 TB seagate HDD
Thanks
