Need advice about power supply
I need to know if i should upgrade my power supply?? Please keep in mind that im also updating my ram to 16gb of ddr 1866, and also im adding a video capture device called the Avermedia live HD Please help this is my current setup:
Asus Sabertooth 990FX R2.0 AM3+ Motherboard - ATX, Socket AM3+, AMD 990FX/SB950, DDR3 1866 MHz, SATA III (6Gb/s), RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCIe 2.0, CrossFireX Ready
AMD FD8350FRHKBOX FX-8350 Eight-Core 4GHz AM3+ Processor - AM3+, Eight-Core, 4GHz, 16MB, 125W, Unlocked
8gb 1333 ram
XFX FX-785A-CDFC AMD Radeon HD 7850 Double Dissipation Edition Video Card - 2GB GDDR5, 860MHz, Dual MiniDP, HDMI, Dual DVI, PCI-E, Double Dissipation Edition, CrossFire ready
My power supply is 750 watts.
6 answers Last reply
More about need advice power supply
  1. 750 watts is enough
  2. 750w is VERY overkill.
    If you only have 1 GPU, 500w is more than enough. Make sure your 750w PSU is from a good company. Many PSUs from unreliable companies (coolermaster, raidmax, coolmax, etc.) only make 2/3 or less of their stated wattage.
    What company makes your 750w
  3. You can see my stats in my sig, and I run a 450w psu.
    Calculate what you need here:
    Which PSU? Just curious.
  5. Dammit, you made me look. It's a 650w!! Not sure why I had 450w in my head. It's an antec. I was especially concerned when I just went to the watt calculator site, entered my OC info, and it said I needed 410 minimum.
    Still, I agree with you above that 500w should be more than enough, but OP should run the calculator to be sure.
  6. Only reason you would need to upgrade is for future upgrade expansions like sli or cross fire.
Homebuilt Power Supplies Systems
