HehHeh..Nah, I just have a lot of components and stuff. Understand that I used the reference chart that Arrow provided the link to and the formula listed there (total wattage for components in list you have X 1.5. So if the chart and/or the formula is wrong, then my results are too. Even if the chart is more or less accurate, the individual components I have will most likely differ a bit in wattage requirements than the general ones listed in the chart.What you got? A national defense computer?
That gave around 521W...still more than my existing 400W PS I'm using now.I tend to make it 10/7 or divide by seven, multiply by ten.
My Enermax I ordered (EG651P-VE FMA) gives a base output of 530W and a Peak of 651W...that SHOULD be enough...I hope.BTW you can get a 550W supply.
