Tom's Hardware > Forum > Mobility Brands > Nokia > Wierd problem when using Nokia PC Suite
Forum Mobility Brands : Nokia - Wierd problem when using Nokia PC Suite
Archived from groups: alt.cellular.nokia (More info?)
Mike Bradley Wrote:
> "Cyberon" Cyberon.1st1l4@news.cellbanter.com wrote in message
> news:Cyberon.1st1l4@news.cellbanter.com...-
> Okay heres the deal i got a Nokia 6610i and just installed a CA-42
> Connectivity Adapter Cable and Nokia PC suite. Not the funny thing is
> it works... So what is my problem... well..
> Once i connect my phone to the cable i can no longer use my Logitech
> Mouseman Cordless mouse... It simple refuses to work, and as soon as
> i
> disconnect the phone, my mouse works again. And while connected i can
> perform all the functions in the PC Suite without a problem, that is
> using some nifty tab movements, since the mouse doesnt work during
> the
> connect.
> Has anyone experienced this problem and know how to get my mouse to
> work while the phone is connected?
> Or should i just do what i'm thinking about, and go out and invest in
> a
> newer mouse.-
> Which Windows version are you using? Does your mouse have one of
> those
> little PS2-USB convertors on the plug? Can it be attached to a PS2
> port,
> or to a different USB port?
> Always worthwhile looking for a newer driver for the Logitech.
> Take control of your Nokia phone with LogoManager
> http://www.logomanager.co.uk
Im Running Windows XP, pack 2. Everything is fully upgraded via Windows
Update.
Logitech drivers is the newest available for this mouse.
And yes it is one of those cordless ones that comes with a converter to
PS2, but i have it in the USB port.
I got 2 USB ports, on one is a HUB with 4 extra ports. My configuration
was Mouse and CA-42 cable on Hub and Printer on the second port in the
computer. Concidering you
Hehe... Guess what... I suddenly realized that i did not follow the
first rule of "Howto solve problems with USB devices" - Try moving the
USB cables around. So i switched my printer to the HUB and my mouse to
the PC port and now it works perfectly.. I guess the problem is because
both mouse and CA-42 cable use virtual com ports, they conflict when on
the same port (through the HUB).
As soon as i did the switch both mouse and phone works at the same
time.
Cyberon
Sponsored Links
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
