Can I use wireless USB g netgear adapter with wireless n belkin router to G netw
can I use wireless USB g netgear adapter with wireless n belkin router
7 answers Last reply
More about wireless netgear adapter wireless belkin router netw
  1. The Belkin N should be b/g/n, and if that is the case it will work with the g USB adapter.
  2. I have a belkin g and a cricket broadband, and I can't get them to connect.
  4. If your Belkin is b/g/n it means that any wireless adapter rated b or g or n can connect to it. As long as you are using a compatible security protocol (WEP, WPA, WPA2 ...) you should be able to connect without any trouble.
    WEP, WPA, WPA2 ? I'm sorry im not familiar?
  6. I have an archos 101 tablet and it says my wifi is on but i can't connect to the internet. i also have a problem transfering movies from my itunes to my tablet?
  7. Those are all wireless network security protocols.
    Your tablet is new so none of that should be a problem for you.
    Be sure your wifi is on, check available wifi networks available. select your home network and you should be prompted for a password. Type in your password and press connect. That should be all you need to do! The same goes for your USB adapter...
Connectivity Wireless Routers Netgear USB Belkin Wireless Networking
