Closed Solved
Help choosing
Hello, I been looking at graphics cards for a new gaming PC with a budget of $1,200 and am wondering if there was a big performance difference between the Nvidia GeForce GTX 660 Ti and the GTX 670 as the 670 is around $70 more.
3 answers Last reply Best Answer
More about help choosing
  1. Best answer
    http://benchmarkreviews.com/index.php?option=com_content&task=view&id=971&Itemid=72&limit=1&limitstart=6
    here this might help I have a 670 I was also thinking about getting the 660ti
    think about it this way if a card is priced at 400 it will run like a 400 dollar card same with 300 you should look at 7950 great for ocing
    however If i had to choose between one for your budget go for the 660 ti
  2. I was looking at the 7950 but couldn't find a performance comparison to the nvidia cards so I will look at the AMD again but I think I will get the 660 ti. If you had any recommendations for the the type of 660 ti it would help but thanks for your help.
  3. Best answer selected by razerback99.
Graphics Cards Gtx Graphics
