Tom's Hardware > Forum > Home Cinema Equipment > Ptv Replaytv > Replay 4504 Internet Connection Problem
Forum Home Cinema Equipment : Ptv Replaytv - Replay 4504 Internet Connection Problem
Archived from groups: alt.video.ptv.replaytv (More info?)
After 2 years of error free operation, I unplugged my 4504 to install a new
TV. Once I was connected to the new TV, everything worked fine accept the
internet communication connection for the Channel Guide update.
When I go to the Network setup screen and select Auto DHCP I get an unable
to connect message. I was lucky enough to write down all the internet
numbers (IP, Gateway, DSN1 & 2, etc) before I unplugged the unit. I tried
these numbers, but I still get the unable to connect message.
I Rebooted the unit by unplugging it, waiting, and plugging it in and trying
both actions described above.
I direct connect the Ethernet cable into the cable modem, then reset the
cable modem and retried both actions above.
Calling Replay Support, they told me to return the unit for $79.95 plus I
pay for shipping.
Does anyone have an idea to resolve the problem or does unplugging the unit
destroy it?
-- Bruce
Sponsored Links
Do you have any way to test the connection? That is, a desktop
or laptop you can put on the network?
Have you tried unplugging EVERYTHING from the Replay for several
minutes (to an hour)?
> destroy it?
It should not, but it's possible a static discharge or something
else fried a component.
Bill Cochell (lose the _TUDE_ to reply directly)
"Sometimes I wonder whether the world is being run by smart
people who are putting us on or by imbeciles who really mean
it." --Mark Twain
Reply to Anonymous
Try rebooting again but unplug the ethernet cable as well. Then plug it
back in and then plug in the power cord. It may make a difference. I
also solved a similar problem by just holding the power button for 20
seconds and forcing a reboot.
MrBruceKA@ComCast.Net
> a new TV. Once I was connected to the new TV, everything worked fine
> accept the internet communication connection for the Channel Guide
> update.
> unable to connect message. I was lucky enough to write down all the
> internet numbers (IP, Gateway, DSN1 & 2, etc) before I unplugged the
> unit. I tried these numbers, but I still get the unable to connect
> message.
> trying both actions described above.
> the cable modem and retried both actions above.
> plus I pay for shipping.
> the unit destroy it?
> -- Bruce
Reply to Anonymous
> pay for shipping.
Gee, 79.95...
for $79.95 they will ship you a brand new 5504, free shipping.
Reply to Anonymous
>> pay for shipping.
> Gee, 79.95...
for the 79.95 + the cost of shipping both ways, you can buy a refurb
4508 and resell the one you have or keep it for parts
Reply to Anonymous
There are 1141 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
