Tom's Hardware > Forum > Audio > Audio Technology > Phantom Power Filtering (removal of phantom power)...
Forum Audio : Audio Technology - Phantom Power Filtering (removal of phantom power)...
Archived from groups: rec.audio.pro,rec.audio.tech (More info?)
Hey Everyone. I can't seem to find the answer and/or product to
satisfy my needs: a phantom power filter/remover.
I have a ribbon mic I'd like to gig with, and the PA systems we use
normally plug into have an all-channels-on/off for the phantom power.
Our vocalist uses a condenser mic, so she needs it on. If the phantom
power hits my ribbon mic, it might permanently damage the ribbon
element.
Does anyone know of a DIY homebrew solution?
Thanks,
Chris
Sponsored Links
"Chris Breitner" <chris_breitner@hotmail.com> wrote in message
news:ba4f639a.0406301644.1d98dd6@posting.google.com
> element.
Measure the resistance from pin 2 and 3 to pin 1 using an ohm meter with
limited current, such as a good DVM.. If it is infinity, you don't have a
problem, and then stop worrying.
Reply to Anonymous
news:ba4f639a.0406301644.1d98dd6@posting.google.com...
> element.
Two options :
1:1 Isolation Transformer - The better Transformers usually cost more and it
is not difficult to spend $100 on a decent Transformer ...
Capacitors in Series with the Signal - 47uF is usually adequate but can
depend on the input impedance of your mixing desk - typically 1K or so which
will give you low Frequency rolloff with a -3dB point of 3Hz Of course the
Desks internal Decoupling Caps will be in Series with this so this will
probably raise your -3dB point to 7 Hz or so.
D Pin 2 ---------------||--------------- Pin 2 of the Mic
e +ve
s Pin 3 ---------------||--------------- Pin 3 of the Mic
k Pin 1 ------------------------------ Pin 1 of the Mic
Arent Ribbon Mics a bit delicate to take on the road ???
Regards
Richard Freeman
Reply to Anonymous
"Arny Krueger" <arnyk@hotpop.com> wrote in message
news:tPmdnahRCY1rw37dRVn-vw@comcast.com...
> > element.
Of course it could have a Transformer isolated output in which case he could
read a near short and still not have to worry ....
Reply to Anonymous
> element.
> Thanks,
> Chris
If its your board, go into one of the channels and remove the two
phantom resistors from the channel you want to use the ribbon on.
It will just cost you some time (if you know what your doing that is)
Otherwise, a good isolation transformer as some else suggested externally
Bob
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Reply to Anonymous
> element.
Someone will, I hope, correct me if I'm wrong, but couldn't you just
lift the ground and go with a floating ground? The potential is between
pin 1 (the ground) and pin 2 and between pin 1 (the ground) and pin 3.
There is no potential between pins 2 and 3 because there are equal
value resistors between them and the +48V of the phantom power.
I'm assuming, of course, that cutting the ground near the mic will
still provide you with adequate noise shielding, etc.
- Logan
Reply to Anonymous
> element.
> Thanks,
> Chris
You could use a battery phantom power supply box for this.
It may sound silly, but if it's off and has no batteries in it, it should
just block the dc and pass the mic signal.
You should check with a meter, just to make sure.
Reply to Anonymous
"Chris Breitner" wrote ...
> product to satisfy my needs: a phantom power filter/remover.
> we use normally plug into have an all-channels-on/off for
> the phantom power. Our vocalist uses a condenser mic, so
> she needs it on. If the phantom power hits my ribbon mic,
> it might permanently damage the ribbon element.
It might help to actually reveal the make/model of your
microphone. It may be one that tolerates phantom power
just fine without any mucking about. Especially if it is a
newer one that presumably survives life on the road. (?)
Reply to Anonymous
"Logan Shaw"
** Why don't you try out your own idea and check your assumption ???
............... Phil
Reply to Anonymous
"philicorda" <philicorda@azriel.tydrwg.org> wrote in message
news:pan.2004.07.26.04.51.37.969434@azriel.tydrwg.org...
> > element.
> > Thanks,
> > Chris
But if it uses polarized capacitors (quite likely), they will
be facing in the wrong direction.
Reply to Anonymous
One possibility I didn't see presented is a separate mic pre for the ribbon,
which then goes into the line in rather than through the mic input. There
are a couple of "buy it now" Studio Projects VTB1s on ebay right now for
$129. Not an un-useful purchase anyway, and it easily fits your
requirements.
http://cgi.ebay.com/ws/eBayISAPI.d [...] 30779&rd=1
Roger W. Norman
SirMusic Studio
> element.
> Thanks,
> Chris
Reply to Anonymous
> element.
Blocking caps will remove DC, but that won't do anything for the thump
when you power it on. A transformer will remove DC, but again you need
to plug it into the power supply first, then plug the mike into it, because
it doesn't do anything about the thump from an imbalanced phantom supply.
And, unless it's an RCA mike with a center tap that hasn't been lifted,
the power-on-thump from a badly built phantom supply with mismatched
resistors is the only problem.
What is this mike, anyway? If it's an M-500, don't worry about it.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
"Logan Shaw"
When this is actually the case, there's no problem at all using phantom
power with a ribbon. The reason it can be a problem (aside from mikes
with center ground taps on the transformer secondary) is that sometimes
those resistors are not very equal values. I'm not going to mention any
particular brand of mixers, but suffice it to say that some of the cheaper
ones out there don't match the supply resistors very well. This also badly
degrades common mode rejection as well as making for an issue with dynamic
mikes.
--scott
Reply to Anonymous
No, the ribbon mikes I own are plenty rugged. Besides, people bring
their violin on the road, don't they? And their girlfriend? My BK-5's
are less delicate than my girlfriend by a wide margarine.
ulysses
Reply to Anonymous
> element.
You've gotten plenty of good advice so far, but the one thing barely
mentioned is that besides a center-tapped output transformer, a
defective microphone cable is just about required in order for phantom
power to damage a ribbon mike. So buy yourself a nice $25 mike cable
that's a different color than all your other mike cable. Treat it
gingerly and label it "only for XXX ribbon mike." Don't let anybody
step on it, tug on it, tie it in knots, or run it over with a rack full
of heavy equipment. This will cost a heck of a lot less than a good
isolation transformer.
ulysses
Reply to Anonymous
In this place, Justin Ulysses Morse was recorded saying ...
> My BK-5's are less delicate than my girlfriend by a wide margarine.
.... and the prize for quote of the week goes to ...
> ulysses
LOL!
(BTW - just how wide IS a margarine?) ;)
George
Newcastle, England
Problems worthy of attack
Prove their worth, by hitting back [Piet Hein]
Reply to Anonymous
From what I understand, margarine is really fat.
- Logan
Reply to Anonymous
How does this cause a problem (other than the rejection
issue)? If the same supply is presented to each side, and 1
is open, then current won't flow between 2 and 3 regardless
of the mismatch.
Bob
"Things should be described as simply as possible, but no
simpler."
A. Einstein
Reply to Anonymous
>of the mismatch.
I didn't word that very well at all. If there _are_ center ground taps,
there is a ground path to pin 1, and therefore the imbalance is an issue.
In fact, even with the ground tap, if there are precise enough resistors
and a good enough transformer, it's a non-issue.
--scott
Reply to Anonymous
There are 1175 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
