Hi my 7950 is making weird sounds when it reaches 50% area fan speed but when it's 30 or below or 70 or above it stops and at first I thought the fan was hitting something but I checked it wasn't and I saw another post like this the guy solved his problem by reducing his voltage but my msi afterburner won't lower it its stuck at 1.25 volts I changed the settings to 1. 2 volts but to no avail as msi still says 1.25 volts, I really don't want to rma this since I have no replacement I sold both my older gpus and I have seen people fix this the sound kinda sounds electrical but also sounds like the fans are hitting something.
My system specs are
7950 gigabyte wf3 1150/1500 (load temps 67 degrees vrm 75)
I5 3570k 4.4 ghz h60 cooler 80 degrees load temp
Tx850m
Asusz77 vlk
Antec 1200v2 or v3 idk
Corsair gt series ssd 60gb
2x500gb Seagate hdd
Genuine windows 7 professional
Ati update 13.1
My system specs are
Tx850m
Asusz77 vlk
2x500gb Seagate hdd
Ati update 13.1
