AMD Dual Graphics problem.
January 27, 2013 2:02:12 PM
Hello,
I recently got a new laptop with an A8-4500M and HD 7670M + Hd 7640G (Dual Graphics)
Most games i play aren't compatible with dual graphics like Minecraft and Skyrim.
When i have the dual graphics enabled it just run on the integrated gpu instead of both because dual graphics doesn't work in those games. And when i disable dual graphics it automaticly runs on the HD 7640g. How can i play games on only the HD 7670M? Because i heard people say that almost all games perform better with only the HD 7670 instead of the dual graphics.
Thanks in advance!
a b U Graphics card
January 27, 2013 8:23:46 PM
If you right click the game, do you have an option to "Run with 7670M"?
January 27, 2013 8:47:21 PM
Can you in the bios or catalyst control center disable the part you don't want to use?
January 29, 2013 11:50:19 PM
Hey
The following worked for me:
> Make your Windows 7 battery icon setting to "High Performance"
> While in AMD Graphics Properties (Catalyst Control Center) > Performance > Disable dual graphics.... this will make the dedicated your primary GPU assuming the preceding setting is also true.
> reboot your computer and try your games. They shall run on the 7670M
This works without issues for me. Currently running A10 + 7670M (GDDR3) & 7660G
