Tom's Hardware > Forum > Audio > Audio Technology > PC Controlled Sound
PC Controlled Sound
Forum Audio : Audio Technology - PC Controlled Sound
Archived from groups: rec.audio.tech (More info?)
Anyone aware of what type of product(s) can take audio from a sound card and
split it to various speaker "pairs/zones". I want it so that software on
the PC can control which zones get the music
I found one thing that looks okay... http://www.hacs.com/ab8ss.html (of
course with my luck its out of stock). Even with that thing; I'm not sure
what type of amplifier I need.
Any advice/guidance is greatly appreciated.
Frank
Sponsored Links
That unit appears to be a speaker routing system. Feed it from the
speaker outputs of whatever amplifier would normally drive the
speakers. It allows for two inputs from separate amplifiers. You
appear not to need this facility.
This seems to do what you require. Maybe they offer a cheaper
version with a single input? It seems to be down to you to write
software to control it via a serial port on your computer, though a
sample qbasic routine is offered.
Reply to Anonymous
"Laurence Payne" <l@laurenceDELETEpayne.freeserve.co.uk> wrote in message
news:7qfqe0leci0k8f1vse7kgh89a77f2gqnni@4ax.com...
and
sure
Yea that item did seem to do what I wanted... my question was with what type
of Amplifier I would use with it... I'm not sure what I would need to
connect between the PC and the unit.
What do you think?
Reply to Anonymous
I repeat - whatever amplifier you would normally use to drive the
speakers, if they were sitting next to your computer.
I guess you'll be wanting something better than the plastic "computer"
speakers, designed for very close-up listening? If you're using
speakers designed to go with a domestic hi-fi amp, use one of them.
Are there any special requirements? Very long speaker runs? Need
for top quality?
Reply to Anonymous
news:vn1re0pb6famqum1bm8cc4fj0897vpfq9u@4ax.com...
type
> for top quality?
Long speaker runs would be a yes I guess... I plan on having the output of
this control multiple rooms on different floors of the house. For now the
Amp/Speakers will be mid level and then I might upgrade later on.
The reason I ask about the Amp is that my speakers for my computer dont seem
to use the same type connectors as that unit.... so I wasn't sure if there
was a special type of amp that would.
Frank
Reply to Anonymous
The web page says they are "Quick-detach screwdown terminals". I
think they accept plain old bare wire :-)
Reply to Anonymous
There are 1043 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
