Can i upgrade my system to a ati radeon 7750 or 7770
seanpr92
9
specs at moment it also has a 450 watt psu installed i want to run games like crysis 3 (playable) obviously highest settings isnt important to me but steady fps is also which card would you recommend if not what one can you
system Information
Time of this report: 1/27/2013, 21:38:31
Machine name: SEAN-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-78LMT-USB3
BIOS: Award Modular BIOS v6.00PG
Processor: AMD FX(tm)-6100 Six-Core Processor (6 CPUs), ~3.8GHz
Memory: 16384MB RAM
Available OS Memory: 15614MB RAM
Page File: 2663MB used, 28561MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
Card name: AMD Radeon HD 6670
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6758)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6758&SUBSYS_25081462&REV_00
Display Memory: 1386 MB
Dedicated Memory: 2027 MB
Shared Memory: 3454 MB
seanpr92
9
also with the 770 ive done some research and found its a 2 slot does this mean it needs 2 pci-e or just one? bit confused as its my first gaming pc
ARICH5
yes it will fit.
you do know you wont see a huge improvement over your 6670. youre maybe jumping one or 2 teirs in performance.
you have a decent cpu and ram. id say ya shoulda saved for at least a geforce 670 or a 7950
SMGeaZy
29
I think you should get maybe a step higher like the 7870 or the 7850. Or possibly you could wait for the next gen cards
