I've searched all over... Nvidia problem.
Hello, no game will recognize my Nvidia graphics card, nor can I force them to use it through right clicking and selecting the card, or switching the global settings to it. If I disable my intel graphics card, then I can't even play any games. Please, someone help me. All I can find is a bunch of people telling me to right click it, or make it the global setting, which does nothing at all. I'm so badly wanting to fill the internet with curse words of various origins. Also, I have windows 8.
Related ressources
Graphics card Expert
Its not that!, he has not turned his Intel graphics chip off in the bios has he.
It`s running in tandem. Its loading both video drivers in windows.
So he is getting a conflict between the Nvidia card and the Intel Gpu, on the motherboard or embedded as part of the Cpu.
The game is trying to choose what card to use, as no doubt two video drivers are running at the same time.
Go into the bios of the motherboard and turn the Intel graphics chip set off in there, make sure the Pci-e card slot is set as the default primary out put graphics, set to Pci-e slot in the options in the bios menu, save the settings, and exit the bios.
Then games will default and run with the Nvidia card. And the card will be seen.
Or you forgot, as said to plug the extra power feeds to the back of the graphics card needed from the PSU, for the card to run right. Do make sure the lead from the monitor is plugged into the Nvidia card and not the video port of the motherboard also.
Give it a try !
I'm using a series 7 chronos 15'4 inch notebook from Samsung. I've looked in my bios, and there's no options to turn any graphics card off. I've tried playing both Dolphin and Path of Exile, and they both refuse to even show that there's any adapter but the intel 4000 hd. In the power settings, I have everything set as high as possible. I right click on the games and select Run with graphics processor>High performance Nvidia processor (Default). This gets me no results. I also use the Nvidia control panel to attempt to set the Nvidia card for the individual programs. This doesn't seem to work either. The only thing close to a solution I've seen anywhere is to reinstall windows 8... but I don't have a disk for that.
