Tom's Hardware > Forum > Audio > Audio Technology > Electrolytic replacement in old receiver
Forum Audio : Audio Technology - Electrolytic replacement in old receiver
Archived from groups: rec.audio.tech (More info?)
The big can electrolytics have leaked out goo some time ago in my
Technics SA5770A. The only replacements I found while searching the
web were from newarkinone (United Chemi-con U32D80LG223M63X79HPC). I
need two 22,000mfd @80vdc. Their price of $14.53 each seemed way too
cheap. Is there another source? Or will these be ok?
The receiver still plays ok, but I know a catastrophic end is coming
if these should short out.
Sponsored Links
NewarkIn One is a great distributor -- they have been selling a lot of stuff
through ebay to reduce inventories.
Jack
"Dan Busetti" <menwagoh@msn.com> wrote in message
news:ad8e0b3b.0407100511.71fadff1@posting.google.com...
Reply to Anonymous
has caps like the ones you are looking for:
http://stores.ebay.com/JEA-Capacit [...] eZl2QQtZkm
Reply to Anonymous
menwagoh@msn.com (Dan Busetti) wrote in news:ad8e0b3b.0407100511.71fadff1
@posting.google.com:
To be honest, $14.53 is about right. If you want, you can buy them from me
at $48.77 each. (:> ) Big can electrolytics are generally cheap.
r
Nothing beats the bandwidth of a station wagon filled with DLT tapes.
Reply to Anonymous
On Sat, 10 Jul 2004 17:51:39 -0000, "Rich.Andrews" <spmaway@ylhoo.com>
I'll sell you same "audiophile" ones at twice that price, if you
insist ;-)
Reply to Anonymous
Laurence Payne <l@laurenceDELETEpayne.freeserve.co.uk> wrote in
news:ak73f0p51u0e87igeud7cbi9rtr3hkk8tv@4ax.com:
me
> insist ;-)
My audiophile gold version is $977.00 each and that is my cost...honest!
r
Reply to Anonymous
"Rich.Andrews" <spmaway@ylhoo.com> wrote in message news:<Xns95239E91560E3mc2500183316chgoill@10.232.1.1>...
> me
> > insist ;-)
> r
As Yakov would say, What a Country! If Golds costs $977, what do
Platinums cost?
I ordered a pair from newarkinone for $29+ shipping. I suppose this
big Technics (165 wpc)is worthy of Gold, but utilitarian units will
have to do.
Reply to Anonymous
>Platinums cost?
>have to do.
Just remind us again why you rejected the $14.53 ones?
Reply to Anonymous
Laurence Payne <l@laurenceDELETEpayne.freeserve.co.uk> wrote in message news:<1ri7f0lo3eehpuusu7bkpauh15971hchgf@4ax.com>...
> >Platinums cost?
> >have to do.
I didn't.
$14.53 + $14.53= $29.06.
So I rounded down .06. I ordered (2) $14.53 units.
Speaking of the PS caps, Technics advertising says this unit has
"conservatively rated power supply capacitors."
Reply to Anonymous
If the dimensions are OK, seems like a slam dunk.
I looked up the specs on this old classic at
http://www.vintagetechnics.com/receivers.htm
At 165 wpc, its a brute. +/- 80 volts and 22,000 uF is LOTS of PS filter cap
for a receiver, but for a machine this powerful, its about right.
There is a picture of the guts at
http://www.vintagetechnics.com/receivers/sa5770.htm
Looks to be nicely made. Note particularly the 4 gang (or more) tuning cap.
A simple low frequency FR test will give you an idea as to whether any of
the other caps in the receiver may have partially failed in a more concealed
fashion. Normally cheap DVMs aren't good for FR tests at high audio
frequencies, but most of them are good enough to get a represenative idea of
what's happening at 400 Hz, and 20 Hz. If the response at 20 Hz is more than
a dB or two down from 400 Hz, you've probably got some other dried-out caps
to deal with.
Reply to Anonymous
> to deal with.
Yep, it was a slam dunk. They bolted in and I used some terminal
strips to anchor the leads on the screw terminals. B+ B- are 74.5 vdc.
Sounds much better than before, more power, definition and detail.
Will drive my Infinity Studio Monitors to concussive levels. I have a
test CD from my brother I can use to check bass response.
Reply to Anonymous
There are 530 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
