Closed Solved
Can my Corsair TX650 v1 power an HD 7870?
hello guys.. i was just wondering if my Corsair TX650w v1 can power and HD 7870, because im planning to buy one but im not sure if my PSU is enough.. I know a little bit on computers but not all of it so im not sure..
BTW my TX650W v1 has 2 PCI-E 6 pin connectors and an HD 7870 needs two also, so i guess its not a problem.. i think.. hehe
And oh! i almost forgot, it says that the HD 7870 needs two 75W 6-pin PCI Express power connector.. but i looked at my PSU's box about the 75W 6pin PCIE connector and i cant find any 75W.. all i only see is 6-pin PCIE connector without the 75W.. are the two the same? or do i need to buy a PSU that has 75W 6pin PCIE connector? sorry for this noob question.. haha i really dont have any clue about wattage and such.. LOL
i hope someone gives an opinion to my inquiry.. thanks!
5 answers Last reply Best Answer
More about corsair tx650 power 7870
  1. Short answer -- YES IT CAN.
    What they mean by 75W, is the cable itself. a 6 pin provides 75W, so you are fine.
    Go for it.
  2. thanks JJ1217, now im not worried in buying anymore.. thanks!
  3. Best answer
    A system with an HD 7870 only needs a recommended 500w power supply. 600 watts is sufficient for running 2 cards in Crossfire.
    http://www.realhardtechx.com/index_archivos/Page362.htm
    The 650TX is an excellent power supply and more than enough for your system.
    The 650TX should have 2 x 6+2 pin PCI-E connectors that look like the image on the right.
    http://www.google.com/imgres?imgurl=http://cdn.head-fi.org/5/56/56ff61d3_pcie-connectors.jpeg&imgrefurl=http://www.head-fi.org/t/610509/journey-to-building-a-budget-gaming-monster-computer/30&h=359&w=600&sz=54&tbnid=hntvsEI1dU7fsM:&tbnh=90&tbnw=150&zoom=1&usg=__pDYT9DlMhRbIJ1bmukwSFLtXsoA=&docid=EwvdpMZozQ_EyM&sa=X&ei=5lMHUaSFGIyy8QS2oYCwAw&ved=0CGwQ9QEwAw&dur=2291
  4. It is all good. Don't worry much about the 75w, I could tackle about it, but I would just say your good to go by just having the two 6 pin. anyway 650w is even overkill for 7870. You could have a 550w and it is still more than enough. Good choice of brand and series though.
  5. Best answer selected by z2grimtea.
Graphics Cards HD Power Corsair Graphics
