Hello all, I am brand new to the site as a user but have used the website for information many times, great source of info.
Here are my current system specs for my PC
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
Memory
12 gigs ram
Storage
1x 1tb hdd
1x 320gig hdd
Graphics
Onboard
PSU
500Watt Rosewill
Here is my goal for this project. I would like to be able to transmit high resolution video from my PC to my HDTV which has HDMI inputs. I really would not mind having a wired connection between my PC and my TV, but I face a problem right now. The problem is that for some reason, my current motherboard does not support dual monitor displays when using both DVI and HDMI. I have a 23" 1920x1200 computer monitor that I would like to use in conjunction with my TV as a dual display setup so I can continue to use the computer while streaming video on the other display. As it sits right now, I can only use dual display between VGA and HDMI rather than DVI and HDMI. I found that when using VGA for my computer monitor, the sharpness of the image dropped dramatically, so I do not want to run a VGA/HDMI setup.
I use this computer only for daily tasks, web browsing, video streaming etc, and NOT gaming, that's why I have been able to get away with using on board graphics all this time.
Ideally, I would like a very cost effective setup that would simply allow me to have dual display setup with DVI and HDMI output simultaneously. I would also like there to be audio output through the HDMI cable for sound through my TV if that is possible, but if it is not, it isn't a deal breaker.
My next question involves wireless HDMI transmission. I have been doing some research on some of the top units for this type of video transfer such as the Push2TV and similar devices. It seems the drawback to most of these devices is that it either A) only gives the option to clone the scree, not run as dual display, or B) the range/signal strength is lacking. Is there any unit that does this type of wireless transfer that allows dual display, has a simple USB dongle for laptops (not a big bulky transmitting unit), and is under $200?
My brother has Apple TV paired with his Macbook and it works flawlessly. He can simply press a button to wirelessly transmit his Macbook video to the TV as a dual display. This is the kind of functionality that I want with my Windows 7 notebook.
Thank you so much for any advice you may have.
I prefer to buy from Newegg but that is merely a preference and not a requirement. I do not plan on overclocking any components and have no preference as far as brand is concerned as long as it is a quality product.
Motherboard
CPU
Memory
12 gigs ram
Storage
1x 1tb hdd
1x 320gig hdd
Graphics
Onboard
PSU
500Watt Rosewill
