Problems in games ... radeon 7850
Hello,
I have the following PC specs...
MB: Asrock N68-S3 UCC
CPU: AMD Phenom II X2 550 3.1GHz
HDD: Seagate ST350041 8 AS - 500 GB
RAM 2 x Kingston PC3-10700 - 4 GB ( Total 8 GB )
Drivers: catalyst 13.1
Power supply: Seasonic S12II-620 Bronze SS-620GB, 620W.
Windows 7 - 64 bit
is the PSU enough for my specs ???
I have problems in games, te screen is flickering and then it turns black ....
Thank you in advance :)
2 answers Last reply
More about problems games radeon 7850
  1. You seem to have enough power, have you monitored the temps of you CPU and graphics card?
    CoreTemp for CPU and GPU-z for GPU are tools i use.
    If not overheating then perhaps PSU is failing, look for a PSU tester or do it manually with a good voltmeter.
  2. If the screen flickers and/or it turns black,you should try installing the latest drivers.
    If that doesn´t work,don´t worry.
    So many GPUs from the 78XX series have been shipped malfunctioning,therefore you should do a RMA,if you still have the warranty.
    I know because I have a 7850 and works like a charm but a friend of mine also has one and he has the same issues as you and he´s going to RMA the card.
Radeon Graphics
