I"m a moderate to heavy gamer and got sick of my consoles crappy performance and limited options so I decided to build my first gaming PC or first PC build of any kind for that matter. I quickly realized I need some help. I am undecided about what GPU to get for around $200. There are so many in that price range and have close to the same specs but very mixed reviews. I have more question now then when I started. For example the Sapphire 7870 GHz Editon 2gb DDR/5 has a core clock of 925 MHz but 1536 stream processors. But then the HIS 7870 2GB DDR/5 also the GHz Edition has a core clock of 1000MHz but only 1280 stream processors. So my biggest question is what am I looking for in a good GPU. I'm trying to spend the least $ possible while still being able to play games on high setting and hopefully get a decent lifespan out of it.
AMD-FX 8350 Vishera 4.0ghz 8-core processor, I know I don't need 8 cores for current games but hopefully games in the near future will start using all 8
ASRock 990FX Extreme 3 Mobo
16 GB 2x8 G-Skill Ripjaws 1600MHz (these are from my current PC and I'll be reusing them for now to save $)
Rosewill challenger ATX mid case
Topower 800w power supply Sli/Crossfire ready
Seagate Barracuda 1TB 720RPM SATA 6.0Gb/s
4 pack of cooler master 120mm fans
Cooler Master Hyper 212 120mm CPU cooler
I have a CD drive from my old PC
Not sure if it matters but my monitor is a 32' 1080P HD TV hooked up to my current PC with HDMI
I'm open to any suggestions or if there is anything I'm forgetting. Thanks for your time and any help I receive
