Closed Solved
Will 300W Power Supply handle the Radeon 7750
I have a hp p7-1446s Processor speed 3.4, CPU 4MB L2, Desktop Memory 8GB, AMD Quad-Core A10-5700 with a 300W Power Supply. My question is can this system handle a Radeon 7750 Video Card, at present time it has a Intergrated Card HD7660D.
10 answers Last reply Best Answer
More about will 300w power supply handle radeon 7750
  1. AMD recommends a 400w power supply. It might work but if the card it put under load, your psu could fry.The psu included with the computer is most likely mediocre. Not worth the risk.
  2. Yes. A 300w PSU can handle a Radeon HD 7750. HP PSUs are decent enough for the task. The Radeon HD 7750 only consumes 43w at peak power.
    This is a load of crap.
  4. Please tell +12ratings on psu sticker.
    that not entirely true, it will back to how good is it's 300w PSU...
    is it true/good ones or some overrated 'junk' PSU...
    edit: btw labels can deceive (especially in "unknown" maker)
    +12va......12.0A +12vb.....16.0A PSU-Lite-On Technology, rated Standard Efficiency.
    PSU is a Lite On Technology, rated standard Efficiency DC output +12va....12.0A and +12vb....16.0A Good for 300w if temperature does not get above 77 degrees, then wattage starts to drop above that, don't know total wattage that system may use.
  8. Best answer
    You're fine. Lite On PSUs are of at least average quality which is all you really for something that is not very demanding.
    The amps on the +12v rails are peak amounts rather than continuous. Unfortunately, most PSU manufacture use peak amounts rather than continuous. I know it is peak amounts because 12 amp + 16 amps = 28 amps. 28 amps x 12 volts = 336 watts. That's more than the PSU is rated for and it does not take into consideration the power used on the +5v and +3.3v rails.
    Nevertheless, Lite On should be fine.
    Will using high resolutions on my pc monitor while gaming affect performance?
  10. Best answer selected by gary39.
Graphics Cards Power Supplies Hewlett Packard Radeon Graphics
