[Solved]Black strip on right side of monitor(users right)
I have a samsung 19 inch series 1 sa100 monitor currently running on a 1366x768 resolution with a palit geforce gt 610 2gig video card
my monitor has a black strip on the right side any ideas on how to remove this?
any ideas would be welcome and thanks
5 answers Last reply
More about solved black strip side monitor users right
  1. Make sure the screen is running at it's native resolution.
  2. ^+1
    Make sure you drivers are also updated!
  3. i will try those, thanks guys hope they work
  4. it worked thanks guys, now on 1366x768 resolution
  5. I'm glad it worked out for you, did you update the drivers or change the resolution, or both?
Palit Resolution Monitors Samsung Graphics
