Vga grahics card problem
hi, recently reinstalled windows 7 32 bit and now my pixels are stuck on 600 800, i uninstalled the vga driver and reinstalled it and says it working fine but pixels wont change ? please help, thanks , paul
3 answers Last reply
More about grahics card problem
  1. which graphic driver did you install? can you give us the exact name?
  2. which card are you using ?
    uninstall your old driver, download a latest beta driver and install it. if same problem arise then i think its a hardware problem..
  3. hi thanks, i have the standard vga graphic card that was already on it and i just reinstalled it , the thing is it was working fine unti i reinstalled windows 7 ? and i def havnt messed with anything else ? i will try the beta driver then,
Graphics Cards Windows 7 VGA Graphics
