Does the HD 7850 require two 6 pin power cables?
Related ressources:
- Forum7850 supposed to have Two 6 pin power connectors?
- ForumPower supply only has one 6pin I need two for XTX 6850 Radeon
- ForumAdding a second 6 pin PCI Express power cable to 600 watts PSU
- ForumRadeon 7850 2x 6pin pcl-e connectors help!?!?!?!
- ForumDoes 9800 gt require two 4 pin molex to a single 6 pin connector ?
- ForumHd 7850 not detected
- ForumPSU for Two Six Pin Power Connectors
- ForumNewer Models that use 6-pin PCIe power connection
- ForumCan a 7850 run on a 480 watt arctic psu?
- ForumDoes this power supply have the correct cables ?
- Forum2 HD 7850 's in xfire, or 1 7950/70 for eyefinity
- ForumGa-z77x-ud5h and xfx-R 7850 DD no PCIe graphics
- ForumShould you use 6 pin pcie power connectors?
- ForumComparison of two HD 7850
- ForumI5-3570 and HD7850 2GB or i5-3350p and HD7850 1GB
- ForumDo I need to plug in power cables into a second card?
- ForumGTX 660 or HD 7850 ?
- ForumWill a PCIe 3.0 card work in a PCIe x16 slot?
- Forum[Solved] Which radeon hd 7850 should i get?
- ForumActive 3D capable card (7850?)
- More resources
